Joined: 5/8/2020(UTC) Posts: 10  Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
anyone know if vmix has a discord server? had the thought it would be helpful to connect w/ other vmix customers and answer or ask questions in real time
 1 user thanked guildenstern for this useful post.
I don't see one. There is an unofficial Discord for Birddog. Also, OBS.
Joined: 10/22/2020(UTC) Posts: 7  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Had the same thought a while ago, mostly with the same reasons as you. Increased interaction between (experienced) users, easy demonstration of problems or projects and general exchange of knowledge, among a few others.
Though frankly I am kinda worried the same one-liner vibe that trickled from FB into the forum would eventually end up there as well. On the other hand, corrective measures could be quicker applied to those as well :P
-=- Apparently I even started structuring one back then. Just never set it public cause I reckoned I needed at least one second opinion on some of the structures and channels.
