GT
Best solution to controll graphics automaticly
Joined: 4/21/2020(UTC) Posts: 3  Location: Niedersachen
I would like to use the vmix to show live results for horse riding and I wonder about the best approach to control it automaticly
To get an idea of what it it should do: The different States of the Graphic would be
No. 1: Competitor comes in (countdown starts is running) - bottom box with rider, horsename, nation - top right box with countdown label and countdown
No. 2: Competitor starts (time starts) - bottom box with rider, horsename, nation - top right box with time running - top left box with penalties or points fades in
No. 3: Competitor finishes (result)
- bottom box with rider, horsename, nation - top right box with time running - top left box with penalties or points fades in - above bottom box the current rang is showing
... next competitor comes starts at No. 1 again
The data is servered via a JSON-File (served by a nodeJs app) which might also contain status flags like "state": "countdown" "state": "running", "state": "result . . . and so on
My idea after playing with GT-Title Editor is to make the layouts (No.1, No.2,...) available via pages and trigger those pages with shortcuts called by api calls made by the software that generates the datasource-json
Before I start putting too much effort into this, I wanted to ask here if someone might have a better idea on how to make such an automatic gaphic work in vmix :-)
Every advise is welcome
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Tie the “state” data source to a text box in a spare title then Make a script that monitors the value of that text box and then in turn triggers the appropriate title as needed,
we use legacy xaml titles for something similar , can add animations/visual changes based on the various values in its code behind (keeps things also compact in setting up)
GT
