Joined: 3/11/2021(UTC) Posts: 3  Location: Centennial
Hi VMIX Developer, I have been using VMIX since 2010 and just upgrade to 4K, I hope the next upgrade/update is for the playlist, where at this moment VMIX users only can add a list video, adjust stop and start the transition. When VMIX Developer could update the playlist without the user stopping the playlist when adding some video or adjusting the video? and adding the time frame?
Joei
+1
- Possibility to drag and drop within the playlist and from outside the playlist into it. - Triggers within the list. Like, after a video ends automatically select camera 1 to pgm. - Create stop points, so that you can create a list for a complete show. It takes to much work to create multiple lists. - Order by name / number.
