Device input vmix DIRECTSHOW not found
hello I wanted to know if it was possible to import directshow input on vmix, through VLC media player it is possible for me and can see them easily, with vmix instead no. is there any way to fix? Thanks
Joined: 7/4/2021(UTC) Posts: 428  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
I saw a thread a few hours ago where someone suggested checking the "Show Legacy Devices" box in the drop down. Did you try that?
yes I tried but unfortunately without results
Is it visible in OBS?
I've used OBS before to bring inputs into vMix that I couldn't add natively.
Originally Posted by: salvat95  hello I wanted to know if it was possible to import directshow input on vmix, through VLC media player it is possible for me and can see them easily, with vmix instead no. is there any way to fix? Thanks Install the NDI plugin for VLC and bring into vMix as an NDI source
