TDOYEL
#1 Posted : Thursday, January 27, 2022 3:28:39 AM(UTC)
TDOYEL
Is there a way for Mix 2 to simply follow the Preview/Program switching of the main Mix? I am trying to do two simultaneous mixes. Both have the same sources and need to do the same Merge moves and the same time. The only difference it that they have different graphic overlays. I will be using HTML graphic overlays. Main mix uses Overlay 1 and Mix 2 will have a different overlay via the Layers/Multiview.
#2 Posted : Thursday, January 27, 2022 3:31:17 AM(UTC)
If you use shortcuts to do the switching you can apply them to both (multiple shortcut under the same key can be set)
thanks 2 users thanked doggy for this useful post.
TDOYEL on 1/27/2022(UTC), Fabiano on 1/27/2022(UTC)
TDOYEL
#3 Posted : Thursday, January 27, 2022 3:38:21 AM(UTC)
TDOYEL
Brilliant. I was not aware that the same key could execute multiple commands. That's exactly what I was looking for
thanks 1 user thanked TDOYEL for this useful post.
#4 Posted : Thursday, January 27, 2022 3:46:36 AM(UTC)
Why it's a good idea to read the helpfiles ;-)
https://www.vmix.com/help24/index.htm?MultipleShortcuts.html
