Is it possible to set a shortcut to fullscreen ? I want a shortcut that controls separately fullscreen1 and fullscreen2
There are situations where I want both of them to work, and there are situations where I want only one of them to work
Is it possible?
Originally Posted by: miaviel  Is it possible to set a shortcut to fullscreen ? I want a shortcut that controls separately fullscreen1 and fullscreen2
Is it possible?
have you checked SetOutputFullscreen and SetOutputFullscreen2 ?
Originally Posted by: xaver  Originally Posted by: miaviel  Is it possible to set a shortcut to fullscreen ? I want a shortcut that controls separately fullscreen1 and fullscreen2
Is it possible?
have you checked SetOutputFullscreen and SetOutputFullscreen2 ? in SetOutputFullscreen i can to choose input and value, In none of them can I define input = none , or Value = none What do I need to set to turn it on / off?
Joined: 12/27/2012(UTC) Posts: 5,472  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
Use a blank (colour blackor transparent) input ?
Use a blank (colour blackor transparent) input ? It's going to be easier if someone tells me how to do it with a shortcut that turns on / off
Joined: 2/18/2014(UTC) Posts: 1,844 Location: Stockholm
Thanks: 145 times Was thanked: 299 time(s) in 251 post(s)
Originally Posted by: richardgatarski  that's what I meant: "I only see Fullscreen, FullscreenOn, FullscreenOFF I want to independently turn on and off each Fullscreen via shortcuts and a real button. So I guess I am also asking for a button on the interface top middle of preview and output. Right now one Fullscreen button turns both Fullscreen1 and Fullscreen2 on and off. but I have the 4k version. Where's the options to set button shortcuts for the second Fullscreen? it seems there is SetOutputFullscreen2 but missing
Fullscreen2 Fullscreen2On Fullscreen2OFF"
miaviel, then add your +1 to that feature request.
