laurabehney
#1 Posted : Sunday, January 23, 2022 3:52:39 AM(UTC)
laurabehney
We still aren't able to stream directly to Facebook in vMix (haven't been able to for months. We've been using Vimeo as a workaround, but it's starting to cause problems).
I followed the steps in this document https://www.vmix.com/kno...using-custom-rtmp-server
but I get the following error message. Any help/advice would be appreciated!!
[flv@05355fa0] Failed to update header with correct file size. Error writing trailer of rtmps://live-api-s.facebook.com:443/rtmp/FB-653944268366066-0-AbyOs9w1pHIBIKBR: I/O error
FFMPEG1.Exited
frame= 626 fps= 31 q=30.0 size= 11556kB time=00:00:20.88 bitrate=4533.6kbits/s speed=1.03x
frame= 641 fps= 31 q=30.0 size= 11821kB time=00:00:21.39 bitrate=4526.3kbits/s speed=1.03x
frame= 656 fps= 31 q=30.0 size= 12082kB time=00:00:21.88 bitrate=4522.3kbits/s speed=1.03x
frame= 671 fps= 31 q=29.0 size= 12369kB time=00:00:22.39 bitrate=4524.0kbits/s speed=1.03x
frame= 687 fps= 31 q=29.0 size= 12660kB time=00:00:22.88 bitrate=4531.4kbits/s speed=1.03x
frame= 702 fps= 31 q=29.0 size= 12950kB time=00:00:23.37 bitrate=4538.0kbits/s speed=1.03x
frame= 717 fps= 31 q=29.0 size= 13217kB time=00:00:23.89 bitrate=4532.1kbits/s speed=1.03x
[tls @ 0535c400] Writing encrypted data to socket failed
av_interleaved_write_frame(): I/O error
Last message repeated 1 times
[flv @ 05355fa0] Failed to update header with correct duration.
[flv @ 05355fa0] Failed to update header with correct filesize.
Error writing trailer of rtmps://live-api-s.facebook.com:443/rtmp/FB-653944628366066-0-AbyOs9w1pHIBlKBR: I/O error
frame= 723 fps= 31 q=28.0 Lsize= 13303kB time=00:00:24.10 bitrate=4521.3kbits/s speed=1.03x
video:12952kB audio:376kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown
[tls @ 0535c400] Failed to send close message
[aac @ 0535ade0] Qavg: 753.231
Conversion failed![/size]
#2 Posted : Sunday, January 23, 2022 6:22:56 AM(UTC)
@ laurabehney
Looks like your internet connection was lost.
Have a look at this knowledge base article:
https://www.vmix.com/kno...ng-ffmpeg-streaming-logs
Ive
laurabehney
#3 Posted : Tuesday, January 25, 2022 5:10:13 AM(UTC)
laurabehney
Thanks for the reply. The strange thing is that I can stream using rtmp for Vimeo and it works fine. I have 1T of download Internet speed with a direct connection to my pc.
