Feature Requests
GT Titler dynamic text field sizes
Joined: 5/19/2018(UTC) Posts: 12 Location: Faroe Islands/Poland
Was thanked: 8 time(s) in 4 post(s)
For instance if you need to make lower thirds and/or players list, where firstname is with regular font, and lastname is with bold font. You can use two different textfields, but then they are placed static. That does not look good. Firstname Lastname.So some kind of control, that textfield2 should stick to textfield1, dynamically to textfield1 sie/length. Or if it is possible to insert some small HTML like code snippets, into the text, to make text bold . firstname <b>Lastname</b> .  Capture.JPG (22kb) downloaded 45 time(s).See attached picture for better understanding. If this is created somewhere already, that I did not find, please send me link, so I can add +1 there.
 5 users thanked BugviOester for this useful post.
Joined: 12/27/2012(UTC) Views messages in topic : 5,509  Location: Belgium Thanks: 316 times Was thanked: 1021 time(s) in 838 post(s)
While i admit it would be handy, GT titles were never intended to replace 3rd party title designers and probably won't be on the top of the list for now but who knows. But if it is really important and in urgent need there is still the Legacy XAML title option which gives one more possibilities even. Nothing a few stackpanels wont fix ;-)
+1 We need this quite frequently. Both for different font settings, as well as having two fields on the same line (in GT)
Joined: 1/2/2021(UTC) Posts: 11  Location: St. Lambert
Joined: 7/6/2016(UTC) Posts: 11 Location: United States
Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Joined: 5/20/2017(UTC) Posts: 62   Location: Philippines Thanks: 167 times Was thanked: 3 time(s) in 2 post(s)
Joined: 8/16/2017(UTC) Posts: 25 Location: Lafayette IN
Was thanked: 8 time(s) in 3 post(s)
Joined: 3/3/2021(UTC) Posts: 32   Location: São Paulo Thanks: 1 times Was thanked: 12 time(s) in 5 post(s)
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
Joined: 10/20/2021(UTC) Posts: 3  Location: Aachen Thanks: 1 times
Joined: 9/22/2020(UTC) Posts: 44  Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
Joined: 11/2/2018(UTC) Posts: 44  Location: Blantyre Thanks: 6 times
Joined: 9/10/2015(UTC) Posts: 138  Thanks: 2 times Was thanked: 36 time(s) in 32 post(s)
Not a direct answer but if you're okay with XAML titles (different under the hood than GT) you could do something like this: Code:<UserControl Width="1920" Height="1080" Panel.ZIndex="500" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:mtl="clr-namespace:vMixTitleLibrary;assembly=vMixTitleLibrary">
<Grid Width="1920" Height="1080">
<FlowDocumentScrollViewer VerticalScrollBarVisibility="Hidden" InputMethod.IsInputMethodEnabled="False">
<FlowDocument>
<Paragraph>
<TextBlock Text="First 1" Name="First1" Foreground="#FFFFFFFF" FontSize="64"/>
<TextBlock Text="Last 1" Name="Last1" Foreground="#FFFFFFFF" FontSize="64" Margin="10,0,0,0" />
<LineBreak />
<TextBlock Text="First 2" Name="First2" Foreground="#FFFFFFFF" FontSize="64"/>
<TextBlock Text="Last 2" Name="Last2" Foreground="#FFFFFFFF" FontSize="64" Margin="10,0,0,0" />
<LineBreak />
<TextBlock Text="First 3" Name="First3" Foreground="#FFFFFFFF" FontSize="64"/>
<TextBlock Text="Last 3" Name="Last3" Foreground="#FFFFFFFF" FontSize="64" Margin="10,0,0,0" />
<LineBreak />
</Paragraph>
</FlowDocument>
</FlowDocumentScrollViewer>
<Image Stretch="Fill" Width="1920" Height="1080" HorizontalAlignment="Left" VerticalAlignment="Top" Panel.ZIndex="0" />
</Grid>
</UserControl>
The TextBlock element is dynamic in width unlink vMix's mtl:TextBlockDesign. However, the vMix title interface still happens to work with TextBlock for color, font, style, etc.
Feature Requests
