Shortcut to do multiple functions
Is it possible to create a shortcut to do multiple functions. For example, Cut to camera #2, add an overlay, start stream. I have a new Stream Deck that I am using with vMix.
Originally Posted by: JohnnyBG  Is it possible to create a shortcut to do multiple functions. For example, Cut to camera #2, add an overlay, start stream. I have a new Stream Deck that I am using with vMix. if you define each of these function under the same shortcut key they act as one (in order of the shortcut list) It's in the helpfiles : https://www.vmix.com/hel...m?MultipleShortcuts.html
