Joined: 5/8/2021(UTC) Posts: 11  Location: Burnaby Thanks: 1 times Was thanked: 11 time(s) in 3 post(s)
Is there a way to return multiple variables from one XPATH request via the TCP API? I would like to return all attributes from a specific input.
Joined: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Right. So, would the request be /vmix/inputs/input1/attributes::* ? I have tried a few commands that seemed as though they should return multiple values but I can only get 1 value returned per request. My issues could also be a node socket issue. This is my first experience with XPATH, thanks for the help.
Originally Posted by: tk421  Right. So, would the request be /vmix/inputs/input1/attributes::* ? I have tried a few commands that seemed as though they should return multiple values but I can only get 1 value returned per request. My issues could also be a node socket issue. This is my first experience with XPATH, thanks for the help. Could you be more specific pls. What exactly do you want to retrieve , why with one request , .... more info is always helpful to get proper answers try /vmix/inputs/input[1]
I would like to retrieve the full list of attributes for a specific input node, ex:
<input key="cf0d1391-5d9b-40c8-a3f7-32687e05e249" number="1" type="GT" title="Text Middle Centre.gtzip" shortTitle="Text Middle Centre.gtzip" state="Running" position="0" duration="0" loop="False" selectedIndex="0">
Which I would assume would look something like this
What I'm actually trying to return is the key, position, and duration of a specific input. Because of the async/listener design of the socket connection, the call does not actually return anything, rather a separate listener is triggered with response data from vmix. It would make things much easier if there was some form of id/key in that response. If request A is made and then B is made immediately after, there is the (slight) possibility of that response B returns before response A...correct? Is there another method of consuming TCP APIs without using sockets?
I have tried /vmix/inputs/input[1], which returns the inner text, title, of the node. Also, thank you for your help doggy
My suspicion is the response function from vmix will not multiple return values.
XMLTEXT /vmix/inputs/input[1]/attribute::*
=> Returns the key only, which is the first listed attribute in the node
XMLTEXT /vmix/inputs/input[1]/@key | /vmix/inputs/input[1]/@duration
=> Also returns the key only
