Streamdeck buttons activators
We have three cameras in our setup and I have created a Streamdeck profile with an array of buttons to use shortcuts to adjust the cameras - pan, tilt, zoom, etc. I have also created three buttons, one for each camera, to set a dynamic input to indicate which camera is to be adjusted. So far so good. It all works perfectly. What I would like to do is to change the colour of the appropriate button when a camera is selected (and reset the colour of the other two not-selected camera buttons) so that I can tell at a glance which camera is selected. I have tried activators but cannot figure out how to achieve what I want.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thank you. I'll have a go at that tomorrow.
Thank you everyone for your suggestions. I was doing everything correctly but after a couple of hours of testing and trying various combinations I eventually discovered that if I add an icon to the Stream Deck button then the activator doesn't change the button colour, or the possibly the button background colour changes but it's hidden under the icon.
