3rd Party Software and Development
HELP - Need script for mutiview overlays using dynamic inputs and dynamic values
Joined: 11/21/2017(UTC) Posts: 124  Location: Philadephia, PA Thanks: 31 times Was thanked: 14 time(s) in 9 post(s)
Hi.
I've been beating my head against a wall, trying to create a webscript or VBscript or Companion Custom Command that will allow me to do the following:
Use three variables (dynamic inputs and dynamic values) TO:
2. Set an input for multiview layers (DynamicInput1)
3. Set a layer to change (DynamicValue1)
4. Set an input to fill that layer (DynamicInput2)
The problem is #3, setting the layer requires a comma in the value statement and I can't seem to do that in this context - so I need a work-around.
Here's my use case:
I repeatedly use 1-8 box multiview (layered) inputs.
I want to be able to select which input, layer and input to fill that layer very quickly - and change those parameters mid-show, using as few keys on a Stream Deck as possible:
- Keys in Row-1 (Sets the input name or number (8 buttons - 1-Box, 2-Box....8-Box) - Keys in Row 2 (Sets the layer number (1-8) - Keys in Row-3, Row 4, etc. (Sets the Input number to feed that layer) - One additional key calls a script or provides a Companion Custom Command that combines those 3 variables into a function or group of functions)
That's it. I'd sincerely appreciate any samples or advice that can accomplish this.
Best,
David
FYI vb.net scripting not VBscript Read values from the Dynamics from the API XML and combine them as one string (with the comma included ;-) ) to use in the layer function within the script a similar situation:
Awesome! Thanks Doggy! That’s really helpful.
Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
Companion has presets for that(not sure if only in the beta version), really usefull and fast
Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
I'm struggling with this exact thing using Companion. So far nothing seems to work. Tried using the pr-emade SetMultiViewOverlay function in Companion but you cant use a dynamic value in the Layer field. Also tried VMIX run custom command:
SetMultiViewOverlay Input=40&Value=Dynamic4,66
This does not work either but using a number in the layer parameter works fine.
SetMultiViewOverlay Input=40&Value=1,66
Seems dynamic values are not handled properly in this command. - Unless I'm doing it wrong.
Has been addressed before here , Dynamic values are working just fine The SetMultiViewOverlay value is asking for one value (string in a format x,x). Get the content of the Dynamic , add that before the string containing ",66" and use that and all will be fine One can get the actual content of the dynamic using the vMix API
Ah ok. But in the case of companion integration that is less easilly acheived I think. Not sure how one can concatenate strings in a single button press: Scenario: Mode Button - sets a value to the layer number (1 or 5 in my case) in Dynamic4 Input button - sets the fixed input value - say 66 to layer set in Mode button would need to somehow set a string to equal "1,66" from Dynamic4
I am attempting to set the 2 box L or R content using minimal number of buttons (4 + mode button)
I just cant see how I might do that from Companion
So I probably need to involve a script element I think and call that from a Companion button.
You did say it was available in the WEB API, but cant find the reference. Or will I have to query the XML to get it?
