Feature Requests
Ability to Select Multiple Inputs
Joined: 3/23/2020(UTC) Posts: 140  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
I would like to have the ability to select multiple inputs so that I can easily move them around on the screen for better organization. I see this as particularly useful in the coming vMix 25 with additional categories. It is slow and painful to have to individually select each input to drag into a category, particularly in a large preset. It would also be useful to select multiple inputs to group them together in the input window rather than one at the time.
Let's say you create 3 virtual inputs from an existing input. It would be much faster to scroll to the bottom of the screen, select all three of the new inputs and move them into position adjacent the original input rather than having to drag them around one by one across all your other inputs.
I'm thinking a cntrl-click here to select multiples.
Please give a +1.
Greg Gibson
 1 user thanked greggibson for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: greggibson  Let's say you create 3 virtual inputs from an existing input. It would be much faster to scroll to the bottom of the screen, select all three of the new inputs and move them into position adjacent the original input rather than having to drag them around one by one across all your other inputs.
+1 In the meantime one can speed up the moving using some shortcuts MoveInput on hover, if one sets a Dynamic value can use that value as input position in the MoveInput instead of fixed in the move shortcut
Joined: 6/27/2021(UTC) Posts: 43   Thanks: 50 times Was thanked: 4 time(s) in 4 post(s)
Thanks: 2 times Was thanked: 3 time(s) in 2 post(s)
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Joined: 1/9/2019(UTC) Posts: 86   Location: Stockholm Thanks: 25 times Was thanked: 5 time(s) in 4 post(s)
Feature Requests
