Title Editor Countdown hangs if more than 23:59:59
Joined: 12/28/2021(UTC) Posts: 1  Location: Rovaniemi Thanks: 1 times
Hello. First time poster, fairly new to vMix ecosystem. I was messing around with the Countdown feature and I came across some what oddly looking bug. You cannot set more than 24h for the countdown (should be able to, please vMix devs? unless I am missing something) ok sure. BUT if you send API call to add MORE than vMix can show, it will hang on 23:59:59 for the set amount of time. So if you do like Code:curl http://127.0.0.1:8088/api/?Function=AdjustCountdown&Input=CountdownTimer&Value=3600
multiple times, you will hit the magic number 23:59:59 and UI will hang there. But in reality, the numbers do get added to timer and it will countdown in the background. Once it comes back to 23:59:59, it will start working again (or if you set Current Time to like 10:00:00). This could be fixed by adding new display format DD:HH:mm:ss? So in case it goes over 24 hours, it will show as 1:00:59:59. Or something along those lines? EDIT: Version 24.0.0.72 so latest what you could possibly get.
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
Countdown is designed for short durations, a few hours at most. You will need to look for an alternate solution, such a building your own app to set the text via the API.
Joined: 12/27/2012(UTC) Posts: 5,526  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Can always use date/time functions in scripting , even using vb.net stopwatch is an option
