everything
#1 Posted : Monday, December 27, 2021 7:48:15 AM(UTC)
everything
I have some triggers setup to pan/zoom a PTZ camera on Transition In. The only way I have found to reset the triggers after the shot transitions out is to first put a different input into Preview, and then switch back to the PTZ pan/zoom shot. Is there anyway to reset all the triggers so the shot is ready for use again as soon as it transitions out of live?
sinc747
#2 Posted : Monday, December 27, 2021 1:29:29 PM(UTC)
sinc747
Was thanked: 207 time(s) in 173 post(s)
Can you use a Transition Out trigger to accomplish this?
- Tom
everything
#3 Posted : Friday, December 31, 2021 12:31:00 PM(UTC)
everything
- Tom
You can you use a Transition Out trigger to set the camera back to its starting position, but the triggers do not reset. So if you were to transition back in with that shot, you would not get the pan/zoom trigger.
