Feature Requests
More than one activator per key
this feature would be good especially with xkey LEDs to trigger the red led when an input is in output and the ble led when an input is in preview.
Joined: 4/12/2020(UTC) Posts: 2 Location: Bowling Green KY
+1 I have a group of inputs made from cameras that I want to show blue when in preview on the individual keys but when in input I want 1 key to show for the entire column of presets.
Joined: 11/21/2017(UTC) Posts: 124 Location: Philadephia, PA Thanks: 31 times Was thanked: 13 time(s) in 8 post(s)
Joined: 8/4/2020(UTC) Posts: 16 Location: Mumbai Thanks: 15 times Was thanked: 4 time(s) in 2 post(s)
Joined: 5/21/2021(UTC) Posts: 7 Location: São Paulo Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
+1 I've been trying and trying to get it to work and it seems very odd that it shouldn't be possible.
+1 Really Need this with Streamdeck.
Joined: 7/17/2020(UTC) Posts: 59 Location: Makati City Thanks: 11 times Was thanked: 5 time(s) in 5 post(s)
Joined: 6/26/2021(UTC) Posts: 2 Location: Barcelona Was thanked: 1 time(s) in 1 post(s)
If it is not possible to do this could you at least explain why it is not possible?
Joined: 7/11/2022(UTC) Posts: 6 Location: Gulfport, MS
+1 This would be a game changer. Particularly with xKeys.
+1
We use an X-Key controller with various buttons programmed for camera presets using the preset function within vMix (great feature!). We select a camera preset key to move the camera view into the "Preview" window and then use a "Fade" function to move it to the "Input" window.
We installed light pipes in the controller to indicate which button is currently active for the view in the "Input" window but would like to know which button is active for the next camera view we have selected for the "Preview" window.
I used the "Input Preview" function, with a blinking color under "Type", to indicate the active Preview key with the expectation that the light pipe would go from blinking to steady state when we use the Fade button to make the transition from Preview window to Input window. When I Fade the Preview screen shot to the Input window the blinking light goes out but the steady light does not come on.
Feature Requests
