Instant Replay
Problems with ReplayExportLastEvent
Joined: 12/23/2021(UTC) Posts: 2  Location: Canary Islands
Hello Everyone.
Im having some problems with the ReplayExportLastEvent function.
I work in sports events, and i need to export every replay to the disk so the editor can make the final video as soon as possible.
I made a "Markout" script, so everytime y choose "markout" what happens is
Function=ReplayMarkOut&Input=Nueva carpeta Sleep 5000 Function=ReplayExportLastEvent&Input=Nueva carpeta&Value=e:\jueces
If I don't use the "sleep function" it doesn't work.
The problem is: It works fine with clips bigger than 5 seconds... but If i record a shorter replay it doesn't export the clip.. and the.. starts to fail...randomly
I can't reproduce the error.
if I make only a "ExportLastReplay" it works ok.
Any suggestions?
Thanks very much!!!
Angel
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Any suggestions?
Thanks very much!!!
Angel
Some functions just do take some time to process, vMix scripting does not really check on if the function is completed before going to the next line in the code . Is something to take into account . Didn't realize the function ReplayMarkOut needed an Input specification or even had that option ? And what is your MarkIn criteria ?
Thank you for your replay.
I assume there are some actions that take time... this is the reason a use "Sleep 5000". I thought 5 seconds is more than enough for vmix to make "internal things". Indeed if I don't use the sleep function it doesn't work at all.
The problem is I can't use much more than 5 seconds, because in this type of events (surfing) the action could start within 5 seconds from one surfer to others.. and if this occurs the scripts doesn't start.(cause is started right now)
I press the markin manually.
If I use "markin", then "Markout" an then "export clip" manually it works fine.
Instant Replay
