JohnG
#1 Posted : Saturday, November 20, 2021 8:59:47 AM(UTC)
JohnG
Following a recent update to vMix our PowerPoints no longer stop at the last slide but instead loop round and go back to slide 1.
I have checked all the vMix settings that I can find and there does not appear to be anything set to make PowerPoint loop and there is nothing to select to say "do not loop".
If I step through the slides backwards then they stop at slide 1 and do not loop backwards to the last slide.
How can I stop my slides from looping?
Chris Daum
#2 Posted : Monday, December 20, 2021 8:44:02 PM(UTC)
Chris Daum
Germany
by chance you found out by yourself...
In each input windows you have a loop icon.
If you "ungreen" it loop will end!!
UserPostedImageUserPostedImage
JohnG
#3 Posted : Wednesday, December 22, 2021 4:07:23 AM(UTC)
JohnG
Hi Chris,
Sorry but I didn't express the problem properly.
'Loop' is de-selected.
I have set up a hot key (F7) to step through the PowerPoint slides which uses the 'NextPicture' function to display the next slide.
When I reach the last slide then pressing the hotkey again displays the first slide again. I want it to stop on the last slide and stay there regardless of the number of hotkey presses.
Thanks,
John
ask
#4 Posted : Wednesday, December 22, 2021 11:12:11 AM(UTC)
ask
This has always been the behaviour.
Chris Daum
#5 Posted : Thursday, December 23, 2021 5:51:50 AM(UTC)
Chris Daum
Germany
Originally Posted by: JohnG Go to Quoted Post
Hi Chris,
Thanks,
John
ok, sorry!
You have the possibility to read out the slide number the presentation actually is at (local machine e.g.: 127.0.0.1:8088/api):
And then write a script e.g;
Code:
Dim x As New XmlDocument()
x.Load("http://127.0.0.1:8088/api")
dim position As Integer= (x.SelectSingleNode("//input[PPT Input Number or Name]/@position").InnerText)
If Not position = (last Slide Number - 1) 'Picture Index starts at 0!
API.Function("NextPicture", Input:=45)
End If
With this conditional expression you could press "NextSlide" till doomsday
when "LastSlide" is reached, no shift to slide 1, no matter if "Loop" is "greened" or "ungreened"... :-)
Then create a shortcut "StartScript" Value= YourScriptName
JohnG
#6 Posted: : Thursday, December 23, 2021 7:42:59 AM(UTC)
JohnG
Excellent. Thank you.
We're just about to upgrade vMix to be able to use scripting and PTZ so I will certainly implement this.
