Shortcut template import as a function
Hey!
Does anyone know is there an option to import shortcut template as an function?
I've set up my stream deck to open diferent presets with different buttons. But I'd like to optimize my work a little so that when I open my let's say volleyball preset I want to automatically get volleyball shortcut template to open with this preset and for example if I opened hockey preset I want to get Hockey shortcut template to open with this preset.
I couldn't find a function for this. Does anyone know is there a workaround for this or should I ask from vmix a feature request?
Thank you in advance.
Save your shortcuts with your preset . set the shortcuts as Local shortcuts (See helpfiles) Streamdeck templates are SD specific, check for Smart Profiles for SD maybe
Haha.
Thank for your reply. I added local shortcuts on first time too but I just forgot to save the preset with local shortcuts. So yes, that worked fine.
Thank you
