I want to have the ability to show two angles of video at the same time but cannot work out if there is a way to do it as a virtual input.
Say I have 1 camera wide on a stage and a second camera following specific action on the stage (so zoomed in), I want to see if it's possible to have the wide stage shot at a main image and then the second zoomed camera as a faded image over the first. Hope that makes sense.
I can create an overlay on say #4 and set it to 100 opacity at full screen. This then allows me to select any camera over any other camera as the effect I'm after. Is this the only way or am I missing something somewhere else?
Cheers, Scott.
There are several ways:
- Multiviews/layers - PIP overlay - Overlays
The best ways is what works for you and the production
