playlist bug & playlist editor
Hey all,
I have several MPG-files inside a playlist with some files playing twice. So:
1. Movie1 2. Movie2 3. Movie3 4. Movie1 5. Movie4 6. Movie5
But when vMix2011 plays "Movie1" for the second time (4), it resets itself, and instead of playing Movie4 afterwards, it goes back to 2. and plays Movie2?
Also, I have noticed that the playlists are saved as XML files. I want to create an app that automatically creates playlists for me in that format, but I don't understand how vMix creates the <InputKey> tag. Is this some sort of algorithm based on the filename and location?
THanks in advance!
Joined: 1/13/2010(UTC) Posts: 5,344  Location: Gold Coast, Australia Was thanked: 4746 time(s) in 1631 post(s)
Have you tried vMix 2012? There have been substantial improvements to the PlayList feature.
Martin vMix
Unfortunately, 2012 has the same 'bug'
Upon further testing I have discovered the issue, this will be fixed for the next release.
Martin vMix
Thank you! Do you have an estimate on when this version will be released?
Thanks in advance!
Most likely sometime in November.
Martin vMix
isn't there a quick fix/patch? with this bug, vmix is kinda useless to me at the moment...
Please email info@vmix.com.au and I will send you a test version as soon as it is ready. Regards, Martin vMix
