3 Pages<123>
Damn2Good4U
#21 Posted : Saturday, May 31, 2014 6:31:40 AM(UTC)
Damn2Good4U
richardgatarski wrote:
Dear friends, let me quote The Admin from the first post in this thread (and read it carefully):
Please post any comments or questions regarding these new features below.
All new feature requests should go into the Feature Requests forum as per normal.
cheers!
I got confused here as well, I had already posted to realized that.
I guess Martin should create a folder as "Announcement" locked to Admin only for Announcement and we all can start a thread of discussion for that particular topic in the feature request or whatever category it falls.
#22 Posted : Monday, June 2, 2014 3:41:05 AM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
A couple of additional features in vMix 13:
* Basic Luma Keying
* Key/Fill Input support
* New Streaming Window with quality/bitrate presets and the ability to login to streaming partners directly.
A screenshot is below, showing some of the effects possible with the Key/Fill feature.
admin attached the following image(s):
thanks 3 users thanked admin for this useful post.
madness on 6/3/2014(UTC), Thremir on 6/6/2014(UTC), pasingshot on 6/11/2014(UTC)
Bardos59
#23 Posted : Monday, June 2, 2014 6:56:05 AM(UTC)
Rank: Guest
Groups:
Nice job.....can you also implement the ability to to use images as backgrounds without having to first load them into vMix?.....
Thanks..
Damn2Good4U
#24 Posted : Monday, June 2, 2014 8:34:07 AM(UTC)
Damn2Good4U
Thanks..
+1 on this
I feel it will be nice to load background into vMix without making it as an input to keep the number of inputs to minimal... since you know what your backgound is, I think having a button that says background will be on whatever input we want to place the background e.g. on the Chroma Key level, I can place my background directly on the same camera input by selecting background without having to input a background and then placing the camera input on it... and same for the virtual set for the camera input as well..
Imagine I have six camera inputs + 6 virtual set inputs or background input that makes it 12 inputs in total...
atpt
#25 Posted : Monday, June 2, 2014 5:34:14 PM(UTC)
atpt
Martin when you say:
" New Streaming Window with quality/bitrate presets and the ability to login to streaming partners directly."
It means we dont need FMLE anymore and we can send AAC sound?
Thanks for this new feature, Martin.
#26 Posted : Monday, June 2, 2014 9:46:24 PM(UTC)
It still uses FMLE, just with a easier to manage interface.
You can send using AAC too, if you buy the FMLE plugin.
Note that licensing AAC for use in vMix will cost the same as the plugin anyway, so buying the plugin is recommended.
matrix
#27 Posted : Monday, June 2, 2014 10:21:19 PM(UTC)
matrix
nice job
vmix 13 it's wonderfull
let's go now testing from italy [link removed]
#28 Posted : Monday, June 2, 2014 10:32:49 PM(UTC)
Sorry, that link was a private download for internal testing only.
The public preview will be released within a week or so.
matrix
#29 Posted : Monday, June 2, 2014 10:39:42 PM(UTC)
matrix
:( i'm sorry
vmix take my brain
hassan yaghi
#30 Posted : Monday, June 2, 2014 11:25:42 PM(UTC)
hassan yaghi
Hello martin , please explain this
vmix13
* Title Editor supports changing images
regards
#31 Posted : Tuesday, June 3, 2014 1:18:01 AM(UTC)
If you create a title template that contains images, then these can be changed
using the Title Editor. They will appear in the left hand column like text fields do now.
hassan yaghi on 6/3/2014(UTC)
Peter B
#32 Posted : Wednesday, June 4, 2014 1:25:57 AM(UTC)
Peter B
Great news being able to record the source audio in Mulitcorder not just the mix.
This makes Vmix a valid multi-channel recorder with audio from embedded or camera audio sources.
EVS eat your heart out !
The headphone monitoring mix is very welcome but I hope to see an additional stereo submix output.
This would enable a submix from replay sources sent to an external mixer for foldback with no mics
that would cause feedback.
Martin, you rock, Vmix is unique, there's really nothing like it.
best
Peter
Rinsky
#33 Posted : Wednesday, June 4, 2014 10:02:35 AM(UTC)
Rinsky
Does "Key/Fill Input support" mean that it will be possible to use something like CaspaCG to make overlays with seperate RGB and Alpha Channels?
thecloudmediagroup
#34 Posted : Wednesday, June 4, 2014 3:02:11 PM(UTC)
thecloudmediagroup
Was thanked: 78 time(s) in 43 post(s)
That luma keyer looks great! Can't wait!
madness
#35 Posted : Thursday, June 5, 2014 9:50:24 AM(UTC)
madness
Concerning key/fill, will that only have support for images? or will you be implementing it for video also, meaning the key/fill could possibly be animated...
An animated alpha key/fill would be great IMO if not too much more difficult to implement... Please?
#36 Posted : Thursday, June 5, 2014 10:02:05 AM(UTC)
You can use any input as a key to any other input as the fill.
So you could bring in key and fill as separate inputs from a capture card for example.
Synchronisation is the difficult part, so while it will work ok with live video inputs
using it with a video clip key is probably not going to work.
Rinsky
#37 Posted : Thursday, June 5, 2014 10:15:08 AM(UTC)
Rinsky
Thanks for the reply.
Are you planning to make synchronised live video inputs work with alpha or is that something that depends on the video card?
I know that CasparCG Key/Fill only works flawlessly with the Decklink 4K Extreme, so is there a chance that it's the same with Vmix and that specific video card?
Have you tested something like that?
#38 Posted : Thursday, June 5, 2014 10:46:31 AM(UTC)
It will depend to some degree on the timing of the card.
So it is likely the same results that people have with CasparCG will also apply to vMix.
ClementN
#39 Posted : Wednesday, June 11, 2014 6:54:49 AM(UTC)
ClementN
Romania
admin wrote:
Development of vMix 13 has begun and will include some exciting new features:
* Support for Dual Fullscreen Outputs for supported graphics cards.
These can be independently configured in many different combinations including MultiView/Program,
Preview/Program, Program/Input etc.
Hello Martin,
Will this work with the Hybrid Multi-Monitor (link provided) or it is intended only for graphic cards supporting multiple monitors (do you have an example of a such configuration ?) ?
http://www.intel.com/con...nitor-support-paper.html
Thank you,
#40 Posted : Wednesday, June 11, 2014 9:12:05 AM(UTC)
It is designed for a single graphics card with multiple outputs.
The reason is when using multiple graphics cards Windows has to constantly
copy images between cards and this can have a severe impact on performance.
So while it will still work, you will not get decent performance out of it.
ClementN on 6/11/2014(UTC)
Guest (10)
3 Pages<123>
