Adding a file from explorer into a specified playlist in vmix
Joined: 11/2/2018(UTC) Posts: 44  Location: Blantyre Thanks: 6 times
Good morning, I need a script that will add a file from Windows explorer into a playlist.
Thanks in advance for the assistance.
You can't (directly) . files added to a playlist need to be already an input in vMix
Hint: - first check what functions are available (shortcuts) that can be used in a script - check vb.net programming language
Originally Posted by: doggy  You can't (directly) . files added to a playlist need to be already an input in vMix
Hint: - first check what functions are available (shortcuts) that can be used in a script - check vb.net programming language Oh this is noted. Do you have the script for adding an already existing input in vMix into a playlist?
Originally Posted by: Fountain Kamanga  Originally Posted by: doggy  You can't (directly) . files added to a playlist need to be already an input in vMix
Hint: - first check what functions are available (shortcuts) that can be used in a script - check vb.net programming language Oh this is noted. Do you have the script for adding an already existing input in vMix into a playlist? Being there is no function related to doing that the best script is :
