Zoom Gallery view to multiple Inputs
Joined: 12/14/2018(UTC) Posts: 88  Was thanked: 18 time(s) in 7 post(s)
Having Zoom gallery view perform scale and crop to get each participant as full screen source. Is that doable?
I thought that if I create virtual input from a gallery view and then scale to full screen this Virtual input is usable as a full screen source in another input, but the crop and scale goes beyond inputs bounding box. It thought if I zoom (scale) input and that fits the window I could use this input on other Multiview compositions.
How could you do this? Zoom gallery view and to have each participant (up to 10) as isolated input? Even if it is scaled and quality is not superb it would be nice to have this. Then we could make our own layouts that get scaled down again.
grega
virtual copy for each and reposition/zoom in
Joined: 2/5/2021(UTC) Posts: 38  Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Fiddled with this. It's prone to breaking. Try multi pinning, but even that breaks easily, worse if someonee is going to present.
I found a way that works for me. It's mandatory that all participants leaves their camera on all the time or the layout breaks. Zoom on 2 monitors, one is speaker view full screen and second is gallery view. Then using vMix virtual PTZ you can scale and position each participant as ISO input. Sure you are scaling gallery view, but we do not put any participant full screen anytime. They are always a bit smaller. Having only one computer also works with mix minus, so I as a producer can talk to all without getting my voice on air.
