solo16
#1 Posted : Thursday, December 2, 2021 2:44:51 AM(UTC)
solo16
I have an 3.20GHZ NVIDIA GeFORCE GTX 1060 6GB with 16GB RAM machine.
I see Vmix say ideally you would have 4Ghz processor but is anyone else running 8 callers on a machine of similar spec to mine please?
SuperBill
#2 Posted : Wednesday, December 8, 2021 2:18:46 PM(UTC)
SuperBill
Canada
Close - on one station we use 2060Super, 16gig, i7 10th gen at 3.8Ghz - and it handles 8 callers but its at its max - one stream and recording. NVME drives. It would choke if asked to do anything else. It currently uses 40 inputs, each input tends to increase base GPU mem usage, so we've found keep your vmix preset as clean as possible.
I wouldn't recommend the 1060 card with 8 callers,
#3 Posted : Wednesday, December 8, 2021 8:13:15 PM(UTC)
@ solo16
Actually, the GTX 1060 is probably OK, with vMix Call it has more to do with your CPU and internet connection.
(any recommended NVIDIA GTX or RTX GPU will be able to handle most of what vMix can throw at it)
But you won't be able to handle it without plenty of bandwidth (20+ Mbps up and down)and a 3.0 GHz or faster eight+ core CPU for best results.
solo16
#4 Posted : Wednesday, December 8, 2021 8:39:11 PM(UTC)
solo16
Thanks guys. Much appreciated.
