kenmcl0126
#1 Posted : Monday, December 6, 2021 4:42:10 AM(UTC)
kenmcl0126
My current setup is as follows:
HP i7, 3.6 GHz, 16 GB DDR3 RAM
Motherboard is MSI Kalili2, with Intel Z97 chipset
HP integrated GPU
1 PTZ, HDMI into Blackmagic Design 4K Capture Card in PCIe 16 3.0 slot
1 PTZ, HDMI into Elgato HD60 Pro Capture Card in PCIe 1 2.0 slot
I get 30 FPS and 8 ms render times in the stream (satisfactory for my purposes) until a GT Ticker is added, at which point frame rate drops to 24 FPS and render time jumps to 50+ ms.
I have been avoiding adding an NVIDIA GPU since it will take the only PCIe 16 3.0 slot that I have, and it will force me into running at least one of the PTZ cameras as an NDI input.
I think I know the answer but thought I would check to see if there is anything I could do to improve performance when using the GT Ticker.
#2 Posted : Monday, December 6, 2021 5:19:30 AM(UTC)
kenmcl0126 on 12/6/2021(UTC)
