whatupcraig
#1 Posted : Wednesday, December 1, 2021 12:21:06 AM(UTC)
whatupcraig
I have two titles above. The List, which in the above picture is Raids, and then the content, which in the above case is the #3? wh0urdady: 3 raids. The List is just the title of the content. The content will cycle through 10 items and then will go onto another List such as say subs. What I am trying to do is synchronzie the two. So say Raids pops up the 10 items in list in content flows through and then it moves onto Subs and then would cycle through that list. Right now I have the List title set to auto next and loop every 50 seconds and the content to auto next and loop every 5 seconds. It doesnt sync well. How can I sync these two titles together?
#2 Posted : Wednesday, December 1, 2021 1:14:21 AM(UTC)
Can you rephrase please.
What do you mean by list and 2 titles above, content flows through, it moves onto Subs , how do you loop every 50 seconds, content to auto next and loop every 5 seconds ...
whatupcraig
#3 Posted : Wednesday, December 1, 2021 3:47:43 AM(UTC)
whatupcraig
This csv is the first title. So this is the 'category' if you will of the content.
This csv is the for the content list and is the second title.
I have the first title loop through every 50 seconds then and the second title loop through every 5 seconds. There are 10 items in each 'category'. I am looping through at 5 seconds per item so I want the first title to loop through at 50 seconds, 5 seconds * 10 items = 50 seconds. Not meant to be condescending btw. Just trying to explain where I am getting it from.
What I am trying to accomplish is for the first title to display for the length of the 10 items in the 2nd title and then change once the second title hits a new category, if that makes sense.
There is probably an easier way to do this but I am new to vmix.
raugert
#4 Posted : Wednesday, December 1, 2021 4:58:11 AM(UTC)
raugert
Canada
I would use only one database and put your "Category" in column A and put the "Content List" in column B. You would duplicate the name of the category in column A for each 10 rows of data. That way it will always be in sync.
Screen Shot 2021-11-30 at 12.57.34 PM.png (141kb) downloaded 1 time(s).
thanks 1 user thanked raugert for this useful post.
whatupcraig on 12/1/2021(UTC)
whatupcraig
#5 Posted : Wednesday, December 1, 2021 5:11:25 AM(UTC)
whatupcraig
Thank you!!! This was the solution. Still learning this stuff. Appreciate it!
#6 Posted : Wednesday, December 1, 2021 5:14:32 AM(UTC)
Please use Data source instead of list ;-)
Also guessing you are not using 2 titles, but one with 2 fields ( each can be connected to a different data source )
Could use a small script with some timed and counted for next loops in case list editing is an issue
select item from first list , select 10 from second list in succession , select next from first list , select 10 ... and so on
something like
for x = 1 to 5
select x from list 1
for y = 1 to 10
select y=y+1
next
next
