Thanks: 13 times Was thanked: 2 time(s) in 2 post(s)
Hello. I ask you a question with an earnest heart. vmix utc is a very nice program, but it doesn't have the ability to export data externally. txt or excel. This is a necessary function for the use of statistical and graphic software other than gt designer. The function and usage are similar to vmix utc, but does anyone know of a software that can send data to the outside? Please advise me. thank you.
Rank:: Member
It's a pity that I only saw this problem in 2023. In fact, the vmixUTC project file can be opened with Notepad, and then you can use some scripts to traverse the data and convert it to the desired result.
Joined: 7/1/2023(UTC) Posts: 16  Location: Bridgetown Thanks: 2 times
That is why I stopped using it, and mainly because of it's UI......I now use PanelBuilder, as I can create my own UI, and I can edit certain features using excel or notepad....
