I'm preparing a live event, with several speakers. I've created a title, and added every name to that. I can select the correct speaker by rightclicking the title, and then select it's name. However, is there a way I can do this using a shortcut ? So shortcut x shows the name of speaker one (as an overlay), and shortcut y shows the name of speaker two (as an overlay).
Thanks !
Filip
Joined: 12/27/2012(UTC) Posts: 5,521  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Use the SelectTitlePreset shortcut function, or the SetText shortcut function or use a datasource and keep datasource window open for quick visual selection or use it with the DataSourceSelectRow shortcut function.
Use whats best for your production or combination of
Originally Posted by: doggy  Use the SelectTitlePreset shortcut function, or the SetText shortcut function or use a datasource and keep datasource window open for quick visual selection or use it with the DataSourceSelectRow shortcut function.
Use whats best for your production or combination of Didn't know that, works perfectly. Thanks for the quick reply !
Originally Posted by: fideba  Didn't know that, works perfectly. Thanks for the quick reply !
The helpfiles contains also a complete list of all shortcut (script) functions There are also a ton of instructional videos on the vMix channel of which quite few are about titles, shortcut use, datasource etc
