Feature Requests
TRIGGERS, GT Tittle Designer and other features
Joined: 3/3/2019(UTC) Posts: 9   Location: Brasília Thanks: 1 times
TRIGGERS: 1- I suggest a better way to manage multiple triggers, could be a "Global Trigger Manager", select more than one and move as a drag and drop on the list. 2- Options to: "Select and Add triggers to Input X (one or more inputs can receive and merge triggers from another input)" "Replace triggers on input X (One or more inputs can have the triggers replaced) 3- A trigger to disable triggers. An option to disable triggers to run more than one time in a single input (could be a script too)
INPUT TAB COLOR ON AUDIO MIXER INPUT: A feature to color the audio tab on audio mixer based on the main input tab color could make much easier to find a audio input source
LONGER TIME ON CUSTOM TIME TRANSITIONS: A possibility to use longer times as a transition, we use a lot 4K camera cropping on 1080 productions and this feature will help as to "zoom" or "pan" the input much " much more smoothly"
MORE NDI OUTPUTS
MORE VIDEO OUTPUTS (EXTERNAL TOO)
MORE OVERLAY CHANNELS
PREVIEW INPUT AS A PREVIEW ON MIX 1 Possibility to add a copy of Preview Window as a Vmix Input (To send a custom multiview via any output to the production director instead capture the preview input window, for example)
CHANGE AUDIO OUTPUTS WITHOUT RESTARTING VMIX
MORE AUDIO BUSES
MULTIVIEW: *Option to aling to other layers or guidelines *More layer on multiview
ENABLE AUTO SAVE PROJECT OPTION
DISABLE/ENABLE "LAST" PROJECT OPTION BESIDE THE SAVE BUTTON
GT Title Designer: *Better way to edit colors and other things as effects, transitions on multiple elements selection *Keyboard shortcuts *On "Configure automatic Text Box resizing" option is on "WidthAndHeight" it is much interesting to respect middle and center text aligning and the resizing could have the central point as a reference and not the up left corner as a axis to resize the box. *One transition similar to Continuous to have for a stoped item, for example, a lower third has transition in, one waiting transition and a transition out. Could be a timeline (as After effects) too. :-D *Expand transition could be really diagonal instead size and up together.
To be continued...
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: kardellivemedia  To be continued...
LOL
Feature Requests
