If...Then function in Webscript?
Joined: 11/10/2020(UTC) Posts: 10  Location: Glasgow Thanks: 1 times
Is there an If...Then or If...Else function in Webscript? I'm trying to write a script that will change Audio sources depending on the value held in each of the Dynamic Values.
Also, does Webscript allow variables to be set and then recalled in order to get around the limitation of 4 Dynamic Values?
Finally, are there any comprehensive guides to Webscript commands and syntax as used within vMix?
Thanks.
Originally Posted by: onelifeonesuit  Is there an If...Then or If...Else function in Webscript? I'm trying to write a script that will change Audio sources depending on the value held in each of the Dynamic Values.
Thanks. Have you checked https://forums.vmix.com/...86-Scripting-for-Dummies
Originally Posted by: doggy  Originally Posted by: onelifeonesuit  Is there an If...Then or If...Else function in Webscript? I'm trying to write a script that will change Audio sources depending on the value held in each of the Dynamic Values.
Thanks. Have you checked https://forums.vmix.com/...86-Scripting-for-Dummies Yes. I've been unable to find answers to my questions.
onelifeonesuit, no webscripting does not offer any of that.
Originally Posted by: richardgatarski  onelifeonesuit, no webscripting does not offer any of that. Ok, thanks Richard. Unfortunately I have no experience of any scripting language so I'll have to look for another solution.
Originally Posted by: onelifeonesuit  Originally Posted by: richardgatarski  onelifeonesuit, no webscripting does not offer any of that. Ok, thanks Richard. Unfortunately I have no experience of any scripting language so I'll have to look for another solution. Web scripting and vb.net scripting are created in the same location Webscripting is limited the vMix function vb.net scripting uses the same function ( slightly differently written but with the same elements ) with the added benefit of vb.net logic like if then else etc The link given mostly shows vb.net scripting . vMix does not explain how to do that logic ( except for the use of its functions) as there are enough vb.net tutorials online Code:'see post #5 in previous given link
'post #11 give a simple idea of its logic in vb.net
'WEB
Function=SetText&Input=1&SelectedIndex=0&Value=Some Text
'API
API.Function("SetText",Input:="1",SelectedName:="Headline.Text",Value:="Some Text")
'in vb.net one can use if then else (and more)
dim recording as boolean = true
if recording = true
API.Function("SetText",Input:="1",SelectedName:="Headline.Text",Value:="Is recording")
else
API.Function("SetText",Input:="1",SelectedName:="Headline.Text",Value:="Is NOT recording")
end if
also helpfull
Thanks Doggy. I'm in the middle of a live stream just now but I'll have a closer look at your reply later today. I found Heath's video helpful (and timely) when I watched it yesterday but I would like to see a series that takes scripting from basics for REAL dummies like me to something a bit more advanced with examples of functions and syntax.
Thanks for your help.
Originally Posted by: onelifeonesuit  Thanks Doggy. I'm in the middle of a live stream just now but I'll have a closer look at your reply later today. I found Heath's video helpful (and timely) when I watched it yesterday but I would like to see a series that takes scripting from basics for REAL dummies like me to something a bit more advanced with examples of functions and syntax.
Thanks for your help. Examples in the scripting for dummies thread are real working examples !
