Add an indicator of what's coming out on Fullscreen1 and Fullscreen2  vmix fullscreen.jpg (51kb) downloaded 2 time(s).
Joined: 12/27/2012(UTC) Posts: 5,526  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
In case one can not visually see what is displayed on the full screen monitors and when urgent ( before feature request is considered and implemented) one can pull which input is set to which full screen from the currently usedd preset file and from the API xml one can pull if a full screen is active or not (with script)
I'm not very well versed in using XML API. Does anyone know how to make what I send in Fullscreen1 and Fullscreen2 appear in a browser?
Originally Posted by: abaudio  Does anyone know how to make what I send in Fullscreen1 and Fullscreen2 appear in a browser? You want to see what is displayed in full screen in Browser or displayed as text ? Why in a browser? Seems different that your initial post
I would like to see in a simple way (I was thinking in a browser in the same machine) what comes out of the 2 Fullscreens as in the posted photo
In text format. Es: Fullscreen1>Input 2 Fullscreen2>Multiview
Originally Posted by: abaudio  In text format. Es: Fullscreen1>Input 2 Fullscreen2>Multiview In Browser does not make any sense if you main window and other screens are filled with your project already if simply as text put retrieved info, as mentioned before, in a title as extra input Mind you info from the preset is not updated instantly when changes are made, info from the API XML ( full screen active) is. Here is a comparable way to retrieve for an active state (recording in this case) https://forums.vmix.com/...ng-for-Dummies#post71124
