Joined: 7/9/2020(UTC) Posts: 8  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: minhdowndown  Originally Posted by: chococrispis35  minhdowndown:
on UTC windows
First select buttons to copy.... in utc window select edit and select Duplicate selected thanks. after a few days I knew how to do it. but I have another question, could UTC able to use the internal data directly to button API command instead of title mapping? there is some case I can not use title mapping only. the image below is the example, instead of import the text, could it be a variable from others list/text box in UTC?  Không hiểu câu hỏi của bạn? Nếu cần inbox trực tiếp nhé
Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
One way to enter text to a title is through excel, in the title in vmix you enter it as data source, in utc you will assign a button to advance to the next text (row) or go back
Joined: 10/3/2021(UTC) Posts: 2  Location: Kayseri Thanks: 1 times
Error I get in vMix Universal title controller. How can I run it?
Error while loading controller!
System.Xml.XmlException: Kök öğesi eksik. konum: System.Xml.XmlTextReaderImpl.Throw(Exception e) konum: System.Xml.XmlTextReaderImpl.ParseDocumentContent() konum: System.Xml.XmlTextReaderImpl.Read() konum: System.Xml.XmlReader.MoveToContent() konum: System.Xml.XmlReader.ReadStartElement() konum: vMixController.Classes.Utils.LoadController(Stream stream, IList`1 functions, MainWindowSettings& windowSettings) konum: vMixController.Classes.Utils.LoadController(String fileName, IList`1 functions, MainWindowSettings& windowSettings)
P.S. Don't be afraid, your controller is OK. Report about it on forum.
Joined: 9/2/2021(UTC) Posts: 11  Location: VN Thanks: 4 times
Originally Posted by: chococrispis35  One way to enter text to a title is through excel, in the title in vmix you enter it as data source, in utc you will assign a button to advance to the next text (row) or go back  That's not what I mean. For example, I have a gtzip overlay input to show the yellow/red card for soccer, including logo of the team, Number and Name of the player. Normally I have to import twice for 2 teams and Title Mapping them to each overlay input, but it will cause waste of resources and GPU so I just want to use only 1 overlay input for both and use "button" and "append command" in UTC to change the data, but I could not use the title mapping because the overlay can't decide what to show. The SetText and SetImage API in UTC only accept direct string or directory path, when each Text Field box could be title mapping to multiple elements at the same time. So I wonder if UTC could have something like a variable for each TextField so I could import it to API command? Like this (the image below is just my concept)
Joined: 12/14/2018(UTC) Posts: 87  Was thanked: 18 time(s) in 7 post(s)
SOLVED! I managed with opening template first and then selecting whit which application to open this template. UTC loaded ok. Directly opening the UTC does not work.
Hi, On Windows10, Nvidia 2080 Super I can not open UTC. Program opens in the taskbar but there is no window. On "peeking" it is shown as a gray window.
Any idea? I downloaded the latest one and tried several others I downloaded months ago.
best grega
Joined: 7/18/2019(UTC) Posts: 12  Location: West Africa Thanks: 4 times
Hi, I see folks using UTC for sports events but I was wondering if anyone hase used it to generate election graphics?
Also, is there any documentation tutorials availble for UTC?
Thanks Lassana Tunkara QTV Gambia
Joined: 7/2/2020(UTC) Posts: 7  Location: Forest Lake Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: gre2gor  SOLVED! I managed with opening template first and then selecting whit which application to open this template. UTC loaded ok. Directly opening the UTC does not work.
Where did you find a template to open? I am having the same issue.
Hi, please help with sudden loss of sync between UTC and vMix. For no reason it turned from green to yellow. In UTC settings IP reads 127.0.0.1 port 8088. In vMix settings IP reads http://192.168.9.107:8088. Changing UTC settings to IP from vMix doesn''t help. BTW So far IP 127.0.0.1 has worked like a charm. It may be important that before turning into yellow UTC crashed a few times. Maybe there's an instance of this software running in the background and messing up somehow? Any ideas what could cause the change? Witold
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Make sure that in vMix you haven't set one of the transition buttons between Preview and Program to "Stinger 3" or "Stinger 4".
That's exactly what I did. Thank you. Why does UTC behave like this?
Hi everyone, I have recently updated UTC to the latest ver from Feb 2021. Unfortuantely after I load any of my presets and try to click any of the buttons UTC crashes. In the log file I can see the below info, but it doesn't say much to me. Quote:2021-11-12 13:40:25.6192 INFO 4.0.30319.42000 2021-11-12 13:40:25.6232 INFO Microsoft Windows NT 6.2.9200.0 2021-11-12 13:40:25.6232 INFO Worker Threads:Completion Pool Threads - 1023:1000 2021-11-12 13:40:25.6232 INFO Loading mapped functions. 2021-11-12 13:40:25.6552 INFO Loading templates. 2021-11-12 13:40:25.8571 INFO Searching for data providers. 2021-11-12 13:40:26.5027 INFO Loading window settings. 2021-11-12 13:52:31.4248 ERROR First Chance exception. System.MissingMethodException: Nie odnaleziono domyślnego konstruktora dla typu „vMixController.Help”. Do skonstruowania tego typu można użyć dyrektywy Arguments lub FactoryMethod. w System.Xaml.Schema.XamlTypeInvoker.DefaultCtorXamlActivator.EnsureConstructorDelegate(XamlTypeInvoker type) 2021-11-12 13:52:31.4518 ERROR First Chance exception. System.Xaml.XamlObjectWriterException: Nie odnaleziono pasującego konstruktora w typie „vMixController.Help” Do skonstruowania tego typu można użyć dyrektywy Arguments lub FactoryMethod. ---> System.MissingMethodException: Nie odnaleziono domyślnego konstruktora dla typu „vMixController.Help”. Do skonstruowania tego typu można użyć dyrektywy Arguments lub FactoryMethod. w System.Xaml.Schema.XamlTypeInvoker.DefaultCtorXamlActivator.EnsureConstructorDelegate(XamlTypeInvoker type) w System.Xaml.Schema.XamlTypeInvoker.DefaultCtorXamlActivator.CreateInstance(XamlTypeInvoker type) w System.Xaml.Schema.XamlTypeInvoker.CreateInstance(Object[] arguments) w MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstanceWithCtor(XamlType xamlType, Object[] args) w MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstance(XamlType xamlType, Object[] args)
Any ideas what's wrong?
Thanks: 13 times Was thanked: 2 time(s) in 2 post(s)
I admire your wonderful software. Thank you very much. vmix utc doubles the value of vmix.
It's such a cool piece of software that you expect additional features. If it is possible to output the data to another file For example, as an excel or txt file.
It can also be extended with other graphics or statistical software. It seems to be an unprecedented software. Thank you very much.
 1 user thanked omo for this useful post.
Joined: 9/9/2021(UTC) Posts: 1  Location: Miskolc Thanks: 8 times
Hi! There is a problem I cannot solve. I made goal joy animations for each player, separately. These are alpha channel mov files, so they should be uploaded in an Overlay way. There are 25 of them. How can I choose to select a scorer from a drop-down list after a goal shot, or click on a window to select the right mov file for me by selecting it directly from the disk? Thanks!
Joined: 12/14/2021(UTC) Posts: 2  Location: sao paulo
Good Morning !!! my name is Eduardo I would like to know when we make a donation if there is any utc update .....
Hi, can I upload a file to a List in vmix from UTC? Also, can I have a dropdown or a list view of all the files in the List in UTC so I can easily select them from the list?
If not, does anybody know how it can be done? I'm trying to make a very userfriendly interface, but getting the files in the list is one of the hardest parts right now.
Joined: 2/20/2019(UTC) Posts: 68  Location: Firenze Was thanked: 5 time(s) in 5 post(s)
@Elgarf someone asked you about the chance of using Elgato Streamdeck with UTC but i can't find any answer. Do you think it's possible?
Joined: 1/12/2021(UTC) Posts: 12  Location: Rosenheim Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
Originally Posted by: fabfab10  @Elgarf someone asked you about the chance of using Elgato Streamdeck with UTC but i can't find any answer. Do you think it's possible? That would be great!
Joined: 7/8/2016(UTC) Posts: 53   Location: Ukraine Thanks: 13 times Was thanked: 5 time(s) in 3 post(s)
I'm sorry, maybe I'm blind, but how to setup Merge Transition via UTC? Thx
Joined: 1/24/2022(UTC) Posts: 5  Location: Vitoria Thanks: 1 times
@elgarf. Necesitaria que me ayudases para poder configurar en UTC un marcador de baloncesto. Quisiera que si le vamos asignado a un jugador, 1,2 o 3 puntos, a la vez se sumaria al marcador que aparece en pantalla. Y poder sacar un titulo con los puntos que lleva ese jugador.
Espero tus noticias.
Gracias
@elgarf. Hello friends, My name is Alysson Souza, I have a question about building a UTC file. Please, can anyone help me?  api_cor.png (52kb) downloaded 21 time(s).Is there any way to put a command on the color value? To get the value in the color name list above... The idea is that the button executes the color change command and the chosen color would be in the color list. Would it be possible with some command or api command? Thanks a lot for any help.
