Joined: 11/18/2021(UTC) Posts: 2  Location: Boston Was thanked: 1 time(s) in 1 post(s)
I have both cards. The RTX 3060 was just installed but also just won an RTX 3060 ti. I run up to 8 HD cameras, 12 - 24 1080p playbacks. 2 streams/encodes and recording in 1080p. Some 4k production but that usually limited to a 1 or 2 4k inputs. Which one should I keep?
Congrats on the win!
No question in my mind. The ti has 4,864 cuda cores. The 3060 has 3,584. According to Martin Sinclair, vMix makes extensive use of cuda cores, the more, the better!
Also, compare RAM.
Also check if your motherboard will allow you to do resizable bar. That will work on either card.
Good luck!
- Tom
