Jiraka7
#1 Posted : Wednesday, November 17, 2021 6:42:22 PM(UTC)
Jiraka7
Czech Republic
I would greatly appreciate the ability to customize the Multiview output to my needs. At the moment, it is not possible to choose how many outputs I want to have in Multiview and if I leave some of them blank they still stay there and make the other outputs smaller. It would be best if I could set in Vmix settings how exactly the Multiview would look like by sliding and scaling individual inputs up or down, similar to the Kiloview Multiview Player NDI. This program has very good Multiview customization options, but unfortunately, there is a delay when used with Multiview and the image is not smooth so it is not suitable as a replacement for Vmix Multiview. I would very much appreciate an improvement in this feature.
#2 Posted : Wednesday, November 17, 2021 7:04:59 PM(UTC)
Have you checked if the customize layout and its various options ( settings) i of any use to you?
one can design your own layout too (Multiview/layers) as input and display that
also have a look here
https://forums.vmix.com/...-Custom-vMix-Multiviewer
