kirik
#1 Posted : Sunday, November 14, 2021 6:45:07 AM(UTC)
kirik
Russian Federation
Есть несколько предложений по улучшению меню.
1. Move groups. Now it is impossible to move several shortcuts at once, and sometimes you want to move 10+ shortcuts at once to the very bottom, for example.
move group.jpg (103kb) downloaded 0 time(s).
2. Ability to insert a "separator" into the shortcut table. This makes it visually more convenient to search and distribute
3. Quick change shortcut from the "shortcuts template" window. Opening the settings for each shortcut by clicking on the areas in the image or in the list below
quick change frop pic.jpg (141kb) downloaded 0 time(s).
