Systems
Will my barebone be able to do it ?
I want to use a Zotac barebone PC i already have, a EN72080V-BE.
It has a Intel Core i7-9750H, 32 GB RAM, 500GB NVMe SSD and a GeForce RTX 2080.
I think RAM and CG are enough (please tell me a RTX 2080 is enough for HD 1080p 25fps), but i am wondering if CPU isn't a bit too low.
What i want to achieve is : 4 NDI Inputs, 2 Elgato HD60S+, up to three calls, a few (maybe 10) misc. inputs (video, social, etc...) and simultaneous 1080p 5Mbps streaming and recording (maybe recording in a higher bitrate than streaming).
What do you experts think ? :-) Is CPU or chipset a problem ?
Thank you for your advice.
Joined: 3/28/2016(UTC) Posts: 172   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
I do what you're doing with far less on an older ITX build using a GTX 1660. I would imagine no problem with that setup. Just be sure your network can support the 4 NDI feeds and you manage your NVENC feeds since you're "limited" to only 3 😉. I in the past would actually use an RTX Quadro 4000 (single slot and uses less power and it rocks with 6 NVENC encodings.) The proc I use is an i7700 which seems to be about the same so I would say your good. Originally Posted by: ptnrs  Hi,
Thank you.
Since the original topic, i had a "real world" try and it was, indeed, OK.
Systems
