omo
#1 Posted : Thursday, November 11, 2021 5:14:31 PM(UTC)
omo
Hello.
I am using vmix for sports live broadcasting.
I own other controllers too. but
Since I was in elementary school, I loved the operability of the xbox controller.
I would like to use it for live broadcast instant replay purposes.
I'm having trouble setting up the shortcut.
[img=https://imgur.com/4mPVWfv]xbox controller[/img]
100% speed from joystick neutral
0% speed from leftmost
You want it to be 400% speed on the far right.
But in the replaysetspeed function
If you check pressure enabled
opposite of what i want
0% from neutral
It is fixed at 100% from the leftmost.
This is difficult to manipulate. It's not even intuitive.
[img=https://imgur.com/vEgawp4]problem[/img]
I can't find it even though I searched all the articles related to Xbox on this forum.
Any solution?
thank you.
