3rd Party Software and Development
Change Mix (input) settings, like input source & transition, through API
Joined: 7/10/2020(UTC) Posts: 35   Thanks: 13 times Was thanked: 4 time(s) in 3 post(s)
Is it possible to change the content of a Mix input using REST or TCP Api?
For example can I change the Preview and the Output selected input from a Mix type input?
Also can I execute Cut/Fade and other transitions?
Thank you in advance.
P.S. Also a small feature request, if it’s possible allow us to select main output as input in a Mix. This could be useful in some situations. I know that I can do that with NDI but it’s heavy.
I found the solution. There is a parameter called MIX. This was a little bit tricky because we can’t select the mix by name, only with order on input list (at first, I thought that you must put Input Name on parameters). But this isn’t problem because we usually put them on positions 1,2,3. So, if someone set these parameters Quote:http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&MIX=0 it will be executed on Main Mix and it’s equal with this Quote:http://127.0.0.1:8088/api/?Function=Fade&Duration=1000 But if someone execute this Quote:http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&MIX=1 It will be executed on 1st Mix into the input mix. We can add up to 3 Mix inputs so if we set MIX=2, MIX=3 it will executed on 2nd and 3rd Mix on list. We can’t execute everything but the basic are enough. For example, these parameters, Quote:http://127.0.0.1:8088/api/?Function=PreviewInput&Input=CAMERA&MIX=1 set input with name CAMERA on 1st Mix in input list. Of course, we can use the same parameter on TCP API (as I do)
