NDI
NDI Bridge to send output to remote location
Joined: 10/1/2020(UTC) Posts: 4  Location: Lisburn Thanks: 1 times
Hi folks,
Up until recently, our church was using a room in our main building for the kids' creche, which made it easy to use a mini PC running Studio Monitor to get our output to that room.
Unfortunately, that room is now being used for other things, so the creche has had to move to a separate building just up the road, with a completely separate network.
So, will it be possible to run the NDI Bridge host on the same PC as vMix is running on and then connect Studio Monitor in the other building to that?
Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
Originally Posted by: DarrenNI  So, will it be possible to run the NDI Bridge host on the same PC as vMix is running on and then connect Studio Monitor in the other building to that? Yes, as long as the remote machine is also a Windows machine. NDI Bridge is Windows-only for now.
 1 user thanked Geoff B for this useful post.
NDI bridge is based on webRTC if I'm right. You might want to take a look at SRT as well. Using VLC player should be sufficient.
NDI
