fabfab10
#1 Posted : Thursday, October 28, 2021 6:24:37 PM(UTC)
fabfab10
Italy
Hello everybody, i've been playing with page animation in order to control single elements in a graphic project.
It's pretty simple and clear how to make an element visible using one of the pre-built effects.
I was wondering if there is a way to have an effect for transitioning it out.
Let's say i have page1 with my main graphich, then page2 is adding an element with any transition. If i go back to page1 the new element is cut unvisible. Is there any way to have a transition on this?
#2 Posted : Thursday, October 28, 2021 6:34:58 PM(UTC)
Need to create a page where the added element transitions out
your current page1 might be better to be the initial state of the title then page1 is transition second element in , page 2 transition second element out
fabfab10
#3 Posted : Thursday, October 28, 2021 7:00:25 PM(UTC)
fabfab10
Italy
Thanks Doggy for your message.
If i'm not wrong, on pages you don't use "Transition in" and "Transition out" you just use the PageX mode. In that case i'm only aware how to make an element visible using the effect, otherwise "hidden" should be used.
Do you have any operating procedure on how to use an effect for making an element no longer visible?
#4 Posted : Thursday, October 28, 2021 7:20:54 PM(UTC)
reveal but i prefer Fade (in or out) with a very short time ;-)
fabfab10
#5 Posted : Thursday, October 28, 2021 7:53:22 PM(UTC)
fabfab10
Italy
Doggy,
i'm trying to follow your suggestion but maybe i'm dumb and can't get it properly.
I setup my main graphic and use transition in for all the elementr.
Then Page1 is the basic version with no added elements.
In Page2 i select the new element and choose an effect which is used to bring it in.
In Page3 i should remove this element and now i think i can only choose "hidden" as effect, maybe i'm wrong.....
I i choose hidden then this element is removed with cut.
#6 Posted : Thursday, October 28, 2021 10:09:05 PM(UTC)
Again. Use fade ( depending on) check reverse if needed. Very short time something like 0.01
fabfab10
#7 Posted : Sunday, October 31, 2021 1:17:00 AM(UTC)
fabfab10
Italy
Doggy, i figured out what you mean and this partially answer my question.
Thank you!!
