markz631
#1 Posted : Friday, September 10, 2021 10:19:06 AM(UTC)
markz631
Would like to have more options in the multiviewer. Specifically, a quad version that does NOT have PVW or PGM. This would be a great PTZ operator view for four cams.
RichDanby
#2 Posted : Wednesday, October 27, 2021 7:09:10 PM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
+1 (following October VFLS)
Making program and preview selectable from the list of inputs rather than forced on would make it more flexible.
Use case : dual screen setup with one showing main interface and the other multiview. Multiview can show main inputs (triggered by shortcuts) and interface shows larger program and preview, along with less frequently used inputs.
More +1's for the option to removing program and preview in https://forums.vmix.com/...19-Multiple-Multiviewers
WaltG12
#3 Posted : Thursday, October 28, 2021 8:28:55 AM(UTC)
WaltG12
Can't you just make your own with a Color Input & the MultiView Overlay settings, then assign it to whatever output you want? It allows up to 10 inputs to be added as Overlays & there's even a preset already for the positioning of 4 Overlays in a way that fills the screen.
RichDanby
#4 Posted : Thursday, October 28, 2021 5:34:52 PM(UTC)
RichDanby
It can work to an extent for the original posters use case, though you lose things like automatic input names, audio meters, highlighting of inputs on program and preview, and clip time remaining. Some of that can be solved by scripting but all could be helped by making program and preview optional.
In my case I use the 16 input multiview and would benefit from being able to chose 16 inputs rather than 14.
Howlswolf
#5 Posted : Thursday, October 28, 2021 8:48:06 PM(UTC)
Howlswolf
Canada
+1
nanced
#6 Posted : Friday, October 29, 2021 8:36:37 AM(UTC)
nanced
+1!!!!
David_in_Philly
#7 Posted : Friday, October 29, 2021 9:36:55 AM(UTC)
David_in_Philly
Was thanked: 14 time(s) in 9 post(s)
+1 please add the requested functional as an option and don't take anything away.
Guest (4)
