Feature Requests
Current Color Correction Input Values visible to API
Hey VMix,
It would be amazing if the values for Input Color Correction (Gamma, Lift, Gain, Hue, Sat) could be visible by the API whether that's in the XML file or somewhere else.
Small color adjustments are very important to make sure all sources are color matched and have a well rounded look in a production. These kinds of adjustments often have a dedicated operator that is using a hardware or software panel to manipulate the colors of cameras and sources.
Having the live values of the VMix Color Correction on inputs would allow for feedback to these interfaces to show an accurate representation of what the current applied values are for each input. Currently, if you have such an interface to control VMix Color Correction, the first value sent to Vmix will always be absolute and reset the position of a color value rather than being relative and adjusting the current live value.
I'd love to see these values be available to pull from VMix!
Joined: 11/14/2012(UTC) Posts: 366  Location: Finland Thanks: 235 times Was thanked: 25 time(s) in 23 post(s)
Feature Requests
