GT
How to Show or Hide Layers with Animations
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Greetings to all, just as a test, I have created two layers, each layer has a rectangle and two texts (On and Off), what I am looking for is to make everything hidden at the beginning, then 1.- when making a change in the text On1, show the layer1 2.- when making a change in the text On2, show the layer2 3.- when making a change to the text Off1, hide the layer1 4.- here, when making a change in the text Off2, hide the layer2 So far everything works fine, the problem starts when one layer is hidden, and I want to hide the other, there is the problem because if I hide, the other layer appears, as if saying that a layer must always be visible, I have not been able to solve this, or the events are misallocated ... what am I doing wrong, I hope you help me please. Cheers Translated from Spanish to English with google  GT1.gtxml (4kb) downloaded 25 time(s).
Might be better to describe the intention (logic) of what you want to actually happen (not what happens with the title) Why have separate text fields for on and off ?
The intention is to "hide and show layers with animations", at first they must be hidden, then show or hide the layers, the texts to activate and deactivate is only to capture the event to show and hide nothing else.
I test the file, I would like to know why when I hide a layer and then hide the other layer, the previous layer is shown again, how to make it not behave like this,
GT
