Visual Basic String Manipulation
Joined: 10/20/2021(UTC) Posts: 5  Location: Ontario Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
I want to pull part of the title from the active input to determine which of two cameras is active. I wrote the following test script: Quote: 'What Camera is Active Dim x as new system.xml.xmldocument x.loadxml(API.XML()) Dim ActiveInput As String = (x.SelectSingleNode("//active").InnerText) Dim ActiveQuery As String = "//input[@number=" + ActiveInput + "]/@title" Dim ActiveTitle As String = (x.SelectSingleNode(ActiveQuery).Value) Console.WriteLine(ActiveTitle)
If ActiveTitle Like "[AB] .+" Then Dim WhichCamera As String = Left(ActiveTitle, 1) Dim SceneName As String = Right(ActiveTitle, Len(ActiveTitle)-2) Console.WriteLine("Current Camera is {0}, With Scene {1}", WhichCamera, SceneName) Else Console.WriteLine("Active Output is not a camera") End If
When I save the script I get the error message: Quote: Error Line 10: BC30451: Name 'Left' is not declared
I confirmed that I got similar errors with Right and Len commands. These are standard VB commands, but they don't seem to be supported. Does anyone know of workarounds? Thanks Greg
Use substring
BTW it's vb.net and The left function is not available anymore (according to some google research)
