Slaver
#1 Posted : Wednesday, October 20, 2021 5:16:53 PM(UTC)
Slaver
Was thanked: 8 time(s) in 8 post(s)
Hello folks,
I have received a request from a customer, where I am unsure whether vMix can do that.
I installed two Decklink Duo 2 cards in a systems and two SDI ports are configures as outputs. One output is for the gym and one output for a TV channel. Both want to have different transitions in replay.
Does anyone have any idea how this can be implemented or whether it is even possible?
Thanks in advance and best regards
dmwkr
#2 Posted : Wednesday, October 20, 2021 8:50:42 PM(UTC)
dmwkr
Haven't tried it, but in theory it should work, as you can disable specific overlay and stinger channels for the outputs (https://www.vmix.com/help24/SettingsOutputs.html).
But it is probably a better idea to use this overlay method for the stingers: https://forums.vmix.com/...More-Stinger-Transitions
This way, you could use only one single cut, as every stinger has a cut point per se.
