A few months ago I made a stinger in GT format, I designed it in GT designer and it worked very well for me. When upgrading to recent versions of vMix, it appears that they removed the option for the stinger to stop working on GT formats. Now it does not show me the duration and time cut options of the frames when choosing the stinger in gt format.
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
i Believe the stinger timing using a GT title is based on the transition IN and Out animations within that title. The cut point is at the transition change. SO basically no need to specify in the overlay setup
