Joined: 9/30/2020(UTC) Posts: 56  Location: Manchester Thanks: 10 times Was thanked: 3 time(s) in 3 post(s)
As I see it there are three ways to connect a Behringer X32 mixer to VMIX.
1) Do all of the audio mixing on the X32 and give VMIX a stereo feed. simple, but not optimal if you need to modify the feed based on which video camera is operating. e.g. turn off audio channel 2 when camera two is off. Or you need one person on VMIX and one on the mixing board in constant communication.
2) Send all, up to 8 and possibly more, audio channels to VMIX. X32 sends channels in blocks of 8. Can VMIX separate those into individual audio inputs? And would VMIX be able to adjust and/or mute that many individual inputs based on scene?
3) Send a few individual channels, up to 6, to VMIX. I'm sure VMIX can handle 3 pairs of faders. But if we're down to three pairs of audio inputs there's probably a far more cost effective solution than X32?
Thanks: 4 times Was thanked: 20 time(s) in 19 post(s)
the audio source for each ASIO input is determined by the routing inside the X32 (which has traditionally been done in groups of 8), however you dont need to use groups of 8 inputs in software.. for example you could have ASIO channels 1-16 as X32's XLRs, ASIO 17-32 could be the X32 buss mixes.. then if you added 4 audio inputs in vMix using ASIO 1 to 3 and ASIO 17&18 you would have three mono microphones and one stereo X32 mix as inputs in vMix.. also the block of 8 doesnt exist anymore anyway as X32 firmware update has provided 1:1 routing now..
if you want to mix audio from sources such as cameras with microphones you can send camera audio to vMix busses and use those busses as input sources for X32 mixer channels... then do the all mixing inside X32 and route the mix back as stereo to vMix and adjust sync to match the cameras..
Hi MTONE - We're probably doing it wrong. You're saying you can add individual VMIX audio inputs tied to individual ASIO channels? We're only seeing blocks on 8 on the VMIX side, not individual channels, and we don't know what to do with blocks of 8 in VMIX. Alternatively there is something we can do on the X32 side to get up to 3 stereo pairs sent over to VMIX. We have the latest (the only) X-USB ASIO driver installed on the VMIX machine.
Originally Posted by: DThompson55  You're saying you can add individual VMIX audio inputs tied to individual ASIO channels? yes... if you go to add audio input in vMix, then you see the audio device drop down list where you select the X32 ASIO driver.. once you selected the driver you see a second list propagate below it with all the channels available from the X32 that can be used as vMix inputs.. the first 16 will probably be stereo pairs 1+2, 3+4 etc then each channel individually as 1, 2, 3, 4 etc.. whatever channel you select from the drop down list will correlate with an audio source matching the routing you have setup in X32.. using the example from the previous post, if you have X32 routing set to send 16 XLR sources to USB 1-16 and then you have the mix buss outputs from X32 routed to USB 17-32, this means when you select anywhere from 1-16 in the audio channels drop down in vmix you would receive one of the XLR inputs from the X32 and if you select between 17-32 you would receive one of the X32 mix busses. what you receive in vMix on the 32 channels is determined by the routing you have created in the X32.. Originally Posted by: DThompson55  We're only seeing blocks on 8 on the VMIX side, not individual channels, and we don't know what to do with blocks of 8 in VMIX. im not sure how you could only be seeing blocks of 8 ? I dont have the X-USB card i have the X-Live one but it should look something like this..  vmix-x32.jpg (76kb) downloaded 4 time(s).
Huge thanks for that MTONE. Your visual made us realize we missed seeing something that was there in front of us all along. We've got 32 channels coming over now as we expected all along. Same old X-USB ASIO driver, just clicking the wrong thing.
