NDI
NDI Command - where do I find the commands?
Joined: 8/26/2020(UTC) Posts: 7  Location: MA Was thanked: 1 time(s) in 1 post(s)
I see the shortcut for sending an NDI command to a PTZOptics camera. Great.
Despite a lot of searching, I cannot find a list of commands to enter into the shortcut field for "command".
Is it the PTZOptics VISCA command (multi hex byte string)? I have that list from PTZOptics. Or is there a documented set of NDI command strings/values someplace (not in NewTek's SDK - tried that).
My goal is to move the PTZOptics to a preset that has been entered into the camera from vMix. I know about virtual inputs and all that - but there are some behaviors you get with PTZOptics cameras (freeze on ptz) that only work if you tell the camera to move to a preset.
Thanks much.
 1 user thanked chieftaing for this useful post.
If you found that list of commands let me know.
 1 user thanked mavik for this useful post.
Joined: 6/1/2021(UTC) Posts: 2  Location: Brisbane Thanks: 4 times
Also interested on a list for NDICommand
NDI
