stephencousins
#1 Posted : Friday, October 15, 2021 12:07:48 AM(UTC)
stephencousins
Currently the vMix Stream Deck plugin only works on its own as an individual button.
I would the the ability to use the vMix plugin with a multi-function button on the Stream Deck.
So for example, I can press a button and this will automatically start the stream within vMix, but also turn on my studio lights or close down a specific program on the computer. Essentially, do anything I want outside of vMix as well as inside vMix.
Anyone with me?
ggudnason
#2 Posted : Friday, October 15, 2021 3:47:54 AM(UTC)
ggudnason
Was thanked: 8 time(s) in 7 post(s)
Consider using the bitfocus companion https://bitfocus.io/companion
